FYI, i pretty much copy and pasted this from another forum i belong to, just thought i'd share. I've never done a project to this extent before...A LOT of hard work.
This project is basically adding my old car system which i miss oh so much. I got a Poineer Premier DEHP690UB for Xmas so i figured i'd upgrade the rest too with some subs.
The main idea behind this was to get that bass feel without weighing down the car too much and re-gaining the ENTIRE rear trunk space....thats right....all of it. I say regain because the battery is already back there. How will i do this? well, since i don't have a spare.....you do the math. This proves do be a rather difficult project to say the least.
Additions/mods include:
relocating the already relocated battery
Mapping and cutting a new, stronger hardboard in the hatch (the one you can lift up to get to the spare)
New, larger hinges/fittings
1 - 1200watt amp
1- 12" Audiobahn sub
all necesary wiring
1 - useless doggy wash station.........oh wait, shit, this isn't pimp my ride, i forgot
I was going to use the second 12" sub i had but space is a concern also, it got water damaged in my last car so at low volumes i here scratches coming from the piston of it. Never really lost its kick though.
Anyways, I was trying to figure out how to fit and mount the amp, retain as much space as possible, and still look shiny haha. I brain stormed awhile, then it hit me like a brick to the groin: STEEL TECH!
lol, i remembered i had a bunch of old sets from when i was younger still in my closet. My mom saved it just in case along with a ginormous bag of legos. Woo! turns out it works PERFECT so far. i spent like an hour dissassembling old things i made from like 3rd or 4th grade to get teh parts i needed but it was worth it. I was getting pretty into it for awhile lol.
So that's my story for now. I will be posting pics as soon as everything is done. Hopefully it will look as good as it does in my head....but then again, that never really happens now does it...
Update 1:
After two loooong nights and some of the days ive got the:
Battery fitted, supports installed
Amp fitted (kinda, i factored in for some spacial leeway but not quite enough aparently but still works)
idea of how to fit the sub...this by far is the hardest and taking me FOREVER due to the circular, parabolic shape of the wheel well, and that little piece that sticks up in the middle to secure the spare...WAPITA
Update 2:
UPDATE 2 --- Not quite finished yet but thought id share the bling bling --- i still need to add plexi glass, neons, and seam the carpets
This project continues to prove to be very difficult mostly because of the curvature of the wheel well playing a big part in fitting everything below. The piece that sticks up from the car wheel well to secure the spare also played a large...very frustrating...role
Compared to OEM mine is much stronger, the stuff they use in 1/4" maybe and the hinges they use are a joke so i made my own above
My old large HEAVY box i;ve used since 10th grade made of 3/4" MDF.....now used for parts lol ( i used this box for multiple parts including the battery mount and speaker mounts!):
Cutting and fitting:
Just an ordainary trunk hatch????? I think not......check out whats under that carpet
FINALLY, on the 3rd night things fit and started coming together! And as far as the steel tech thing goes...well the amp is being solely supported on it lol
Underneath it all, a battery sits comfortably:
The adjustable height i can use thanks to the steel tech allows me to control everything the subs do simply by lifting the 'floor' up:
Thinking about adding an extra 12" and having a double layer effect:
1 - 1200watt amp
all necesary wiring
Update 1:
Update 2:
