My car just keeps cranking but wont kick over. I pulled out two of the spark plugs and looks like its soaked in gas. I dont really want to keep cranking it cause it looks like we're flooding it. Not the battery cause we are using a cranking assist function from a battery charger.
Dont know what else to look for when trying to get it running again.
its a 89 t
it sat for a while. it broke down about an hour away frmo my house. iu got it towed and it sat since (about 5 or 6 months of sitting).
it kept blowing efi fuses when if i tried starting it. (as soon as id crank, the fuse would be fine if it were only in the on position.)
so it was in my drive way. i replaced the fuel pump and it stopped blowing fuses but still wouldn't start. just kept cranking. i just replaced the injector relay and resistor pack and just tried starting it again. its still won't fire but it seems to be getting gas because it looked flooded when we pulled the plugs. im at a loss. could the ecu have fried somehow along witht he relay? anyone run into somthing similar or know what else to check for?.
where is the ecu located on those cars. (im a dsm guy and im not too familliar with the mk3)
thanks!
its a 89 t
thanks!
