I just got new calipers and I put them on. After istalling everything and making sure there were no leaks I drove it around my culdasac. The brakes get more powerful if you pump them but if you let off the brake pedal it gets really easy to push again. I'm assuming there is air in the system but I can't get it out. At first when pumping the brakes in my garage I noticed the brake fluid kept going down so I kept refilling it until it didnt go down anymore. now its at max and the brake pedal still goes to the floor. what should i do.
edit. the brakes feel like they are holding the rotor a little. I tried to push the car and the brakes held a little bit.
