So i've done a little research. Spoke to someone I met off craigslist that had some parts for MK3's listed here named Jason. He told me to block off the EGR because it had a Honda one-way valve on it. The blocking of the EGR helped, but it's still running rich and popping and bucking while normal accelleration.
I pulled a code 11, which I saw masks all codes. So I'm currently trying to fix the CEL 11. I pulled the grounds off of the block under the intake manifold, they had tape all around them. I pulled all of the tape off and found no frayed wires. I sanded, brake cleaned, and regrounded the wires. Still, code 11.
I was also told it was giving a Code 52. I just need to verify by clearing out the code 11. Any ideas on how to fix this?
Thanks in advance guys, I look forward to working on and driving this fun little car.
---------- Post added at 11:38 AM ---------- Previous post was at 11:28 AM ----------
Whoops, posted in the wrong section. Meant to be in the 7mgte section. Mods, delete please.
Thanks!
Thanks!
