Hello, just got a new fuel pump put in, but the car hasnt ran before. I have spark, and i have fuel pressure, now i dont have any injector fire. Somebody help me out. What could cause this?
-Adam
do you have the resistor box plugged in? if you dont know what im talking about its the silver box with fins on it behind the driver side strut tower.
i would also check the resistance of the injectors and they are plugged in tight.
There is no other choice. There are two things needed to fire the injector, power and a ground source. Dude. It is one or the other, and the ECU provides the ground path. You never said you had B+ to the injectors.
