ok, so i am in the process of removing my 7MTGE to rebuild it and replace the BHG. i already got directions from this site, but there are still a few problems arising for me.
i cant seem to get the crank pulley loose. i didnt try removing it by cranking over the car, as i had already started the dis-assembly by the time i found detailed instructions on here. i have a big breaker bar, so can i just put the 19mm socket on there and just push untill it comes loose? cause right now all it is doing is spining.... do i just need to keep pushing?
also, i need to remove the fan, as per those instructions, there are those 4 12mm bolts... but when i try and remove them, the fan and its pulley just turn. how can i get these off? if i cant figure it out, couldnt i just remove the water pump and fan as a whole?
thanks for the help.
