ok i put this on off topic because it doesnt apply to the supra but it does apply to my dads 89 toyota pickup v6 4v4 ext cab. if it helps. he bought this new in 89 and has only changed oil, tranny oil, and air filter since be bought it. (truck only has 20k miles) he came home today complaining that his front brakes are locking up bad, he will step on the brake to stop at a light and then when he lets off the pedal the brakes wont disengage and he has to drive it like that, he said he saw smoke coming from the front calipers when he just kept going and it took a bit for the calipers to let off. he took it to midas and they said he needed to change his calipers, rotors, pads, and flush brake lines for a total of like $700 so he's askin me if i can do it for him
(he's not much a mechanic)
anyway i was wondering what you guys would suggest looking at first, i havent had a chance to look at it but i will tomorrow after work.
right now on my list of things to look at is to check his brake fluid and bleed his lines and flush them with some cheepo brake fluid, then look at whats left of his pads and if hte flush didnt help swap out his rotors for some oem calipers and rotors.
any ideas here that could save me the trouble of buying a whole new brake system??
