Does anyone know what Ohm this resistor is?
It is attached to the blue Fuse/Relay block on the driver side kick panel(LHD). I can't get an OHM reading on it and it definitely looks burnt, and there seems to be heat transfer(browning) of the PCB under this resistor.
EDIT: More Pictures
^ where it is in the fuse/relay block
^best photo I could get of the burnt spot
I figured this wasn't "Engine Technical", but if it is in the wrong section, please feel free to move it to the correct place.
EDIT: More Pictures
