I've had an A/C setup sitting for years, with the lines exposed to air. What should I be using to flush/clean them so they can safely be used? Should I replace the expansion valve?
Okay, here's the current plan, I'm not too experienced with A/C, but I do know some stuff and have read extensively, just looking for some other opinions. All A/C components have been exposed to atmosphere for approximately 3 years.
Clean/flush all lines, condenser and evaporator.
"Overhaul" the A/C compressor (install all new seals/o-rings, set clutch depth).
Fill A/C compressor with correct amount of ND-OIL 9.
Replace all o-rings in system with R134a o-rings.
Install R134a fittings to high/low side lines.
Install new R134a retrofit receiver/drier.
Charge with appropriate amount of R134a.
Is there anything I am missing here? Should I be replacing more parts?
Jeff
Jeff
