Pre 89 molding removal
jonny87turbo
203
ohio
gtsfirefighter said:
Yes. On the door there is one 10mm nut towards the front and it was removed.
Basically want to know if there is a special tool you need because of the adhesive. That's what I had problems with.
You can try using a adhesive remover or try wd-40 to loosen up the adhesive.
Then try using a small putty knife to pry the molding loose.
