PowerSteering
xzeror
1,356
Miramar, FL
I have a question when i bought my 1986.5 supra the powersteering wasnt working, its fine to drive but would like to know if anyone had to replace thier powersteering and how much it cost, or if it was just a leak how much that cost to replace the hose. It hasnt been working for a couple of years, according to the guy.
supra1008
1,179
Philadelphia
Well it depends, If its the rack leaking, it can get pretty expensive. The rack is a pain in the butt to replace. I had the rack replaced on my sisters 87 supra and it cost nearly 1k to replace. After that we replaced the rack on my buddies 87 supra while the engine was out for rebuilding. Still it was a pain in the butt dealing with taking the front wheels off and codder pins. Now if its the pump or a hose than it won't be as bad. But most of the time its the rack that goes. Get under the car and see where the leak is coming from. That'll narrow it down to how much its going to cost you. Good luck!
iwannadie
981
gilbert, az
Really, wheels and cotter pins are a pain to take off?
I herd the power steering rack is actually pretty easy, a few bolts and it comes right out(with the motor In place).
For the OP, I would flush out the fluid and add the proper ATF fluid back in. If there is a leak find out where it's at and go from there. I might just be a leaky hose or bad fluid which would be easy to fix.
Kota
105
michigan
ive been deciding what to do with mine, if i drive alot during the day i will go through a whole quart of PS fluid. you can see every turn i make... and its leaking from the rack
Asterix
Lurker of Power
Vienna, VA
A rebuilt rack should be $250 or so. New ones aren't available any more. It's not that bad to replace. The most annoying part is getting an alignment afterwards.
Asterix
