powersteering noise
crrider80
Too soon Jr.
Jun 3, 2006
341
NYC
Hi, for a while i've been running my car w/o powersteering. The complete powersteering system was in the car, just not functioning due to a leaking hose. The leak was caused by the bolt that the banjo bolt screws onto coming loose. W/o powersteering functioning the system would'nt make any noises while turning the wheel. After i fixed the bolt and filled the system with fluid, the PS system makes a whining noise only when i turn the wheel. My guess is that i have to bleed the system and add tad more fluid. How do i bleed my PS system? If fluid isn't my issue, what is? Thanks!
-Steve
crrider80
Too soon Jr.
Jun 3, 2006
341
NYC
Seven M said:
bad P/S pump.......not enough fluid. those are the only two things i know that cause this.
A bad PS pump coujld be the culprit. However, the wheel turns as if the pump is working like it should. Thanks for the fast reply!
-STeve
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
the TSRM tell's you how to bleed the system, I will be doing mine in a couple of days. I put reg PS fluid in mine and it has starting making noise it took awhile though. I didn't not know you where suppose to us ATF. I plan on flushing mine and putting in ATF, I hope it helps.
