Powersteering leakage.
Big Wang Bandit
You Can't Quit Me Baby
Feb 21, 2006
7,551
San Ramon, CA - 925!
Anyone have their power steering system leak? I can't pinpoint the exact location but it must be from one of the high pressure hoses(duh). From what I hear the most common leak spot is from the pump to pinion. Any conformation? Also is this a job I could attempt by myself(my autoshop at my school is being torn down so that means no lift, jacks and jackstands.) or should I have someone at a shop do it?
I wish I could jsut go get a non power steering rack, that would be ideal but more costly heh.
Thanks
BosoMKII
497
NorCal
So you can't see where the leak is? Clean off all the slime and have a friend crank the wheel back and forth while you look for the leak. Do it yourself. Easy stuff. Some basic hand tools and your spare tire jack will be enough.
ratpick63
detroit iron defector
May 4, 2006
62
Glendale, CA
I just had to change the high pressure hose on mine. About $70 from oreilly. Hardest thing was threadin it in place. It's a long piece of metal hard line with about 6 inches rubber on either end and it snakes between the rack and frame over to the driver side. I unbolted pass side of rack from frame to have room to pull line through. Easy though.
