Powersteering: Cressida 7m vs Supra 7mge and gte
S
stsleeper94
Guest
Is the power steering pump the same on all three models or is the Cressida's power steering pump specific only to it. I know that the supra GE has a bolt that threads into it for the attachment of the high pressure line, where as the Cressida's high pressure line threads directly in. Is there a difference and if so will they still work?
Thanks
mrnickleye
Love My Daily Driver !
Jun 8, 2005
825
Mojave Desert, Ca
Lots of lookers !! I believe you'll be the one to try this conversion. Let us know what happens, as I think others will do it too (when needed) if it works out ok. :icon_bigg
S
stsleeper94
Guest
Well I guess I then should keep people updated with my findings. The 7m-ge hardlines off a cressida will bolt into any 89-92 GTE ps flange. However the 86.5 - 88 GE and GTE as well as the 89-92 GE share a different powersteering pump flange then the 7m-ge for the cressida (89-92). I do not believe they fit just based on the visual differences, but have no proof of this. So if you have a supra 89-92 GTE you can use a PS pump from an 89-92 cressida, just a little manipulation of the lines, and if you have the hardlines from a cressida you do not need to get a new ps pump as long as the GTE you are using comes from a 89-92 GTE supra. I still have yet to find a good picture of a 7m-gte 89-92 pump with hardlines
