To all of you electrical supra gurus, I have a little problem. I jumped in my supra this morningand put my passenger window except it would not go down all the way. my drivers side controls only make it go down not up so i leaned over and put the window all the way up. I went to put it back down again and then neither switch would work. Now i took both switches apart and cleaned all the contacts and still nothing. I also tested the motor and that works perfect. I tried to search for a similiar problem in the archives and nothing related to it. Is there a relay or something that might be screwed or something along those lines. Oh yeah the drivers window works fine. Thanks guys
