power steering tensionar stuck
Status
Not open for further replies.
themadhatter
760
Vegas
i am reinstalling my timing belt and need to take the power steering belt off so i can turn the motor over but the darn tensionar is stuck in place no mater what i do it will not budge any one else have this problem
mrnickleye
Love My Daily Driver !
Jun 8, 2005
825
Mojave Desert, Ca
Did you loosen the "pivot" bolt ?? It's what actually holds the p/s pump to the engine. You need to loosen the bolt so the pump will move/swing to remove the belt.:naughty:
Did you loosen the "pivot" bolt ?? It's what actually holds the p/s pump to the engine. You need to loosen the bolt so the pump will move/swing to remove the belt.:biglaugh:
Did you loosen the "pivot" bolt ?? It's what actually holds the p/s pump to the engine. You need to loosen the bolt so the pump will move/swing to remove the belt.:icon_razz
Did you loosen the "pivot" bolt ?? It's what actually holds the p/s pump to the engine. You need to loosen the bolt so the pump will move/swing to remove the belt.:1zhelp:
themadhatter
760
Vegas
wait what? the power steering pump pivots to loosen the belt not the tension pully? then wtf is the adjuster bolt on the tensionar for?
TobyCat
470
Vancouver BC
yup, there's a bolt behind the PS pulley. It's kind of a bitch to get at though...I had to come from underneath with a long extension.
Status
