I'm still trying to track down my power steering leak. Several months ago I replaced both pressure lines as well as the feed line on the bottom of the reservoir because one of the pressure lines cracked. Even with those replaced, I still have a leak. It seems to leak from the driver side dust cover area. The banjo bolt that is above it is fine, no leaking around it at all.
I don't fully know how the power steering system works, is the dust cover JUST a dust cover to block debris from entering the steering rack? It's not supposed to hold in the fluid, right? I took off the boot and of course a ton of fluid drained out of it. Where would that fluid come from? A seal inside of the rack assembly?
