it started out with a loud wine so i checked the fluid level it s good steering got worse till i dint have much power asist so i figured id replace pump steering still did the same thing so i did a rack (rebilt) because right boot was torn and leaking still screwed up so i did another pump since it was under warenty i still dont have any steering
i did relocate the resivior but i dout that has anything to do with it the fluid in the resivior just bubbles up like its blowing air from the return hose so i took the car to a shop they said my pump is good and the rack is bad are they right they said its somthing intearnally in the rack are the seals bad is that where all the air is coming from
