I noticed there is power steering fluid leaking off the bottom of the pump. I checked from the top and bottom and cannot see where it is leaking from. Can the pump itself actually leak or is it most likely a hose connecting to the top of the pump leaking down onto the pump. I will have to remove the accordian hose and power steering resevoir to get a real good look. Also, is there any way to tell by looking at your pump if you have Progressive Power Steering. I searched other threads on here and checked the TSRM, but was not able to tell.
