Power Steering Pump/Parts Washer : Educate me please
ForcedTorque
Join the 92 Owners Group
Jul 11, 2005
6,099
I have a couple of questions.
First, I was just given a parts washer. What type of solvent do I want to use in it?
The first part I need to clean is my Power Steering Pump. Is there anything I need to not let the solvent get into? How would I block it from getting into the vacuum nipples, or inside the pump through the hole for the hose?
Thanks for the help guys!
jdub
Feb 10, 2006
10,730
Valley of the Sun
Kerosene or diesel fuel...there are also specific solvents for parts washers. Diesel works very well.
Remove the vac valve. Solvent inside the pump is not going to be a problem, but I would pour some ATF inside the hole and turn the pump a few times to flush it.
gaboonviper85
3,236
Northeast Philly
Here at work we use "safety cleaner"...sold by "zurnoil"...it's a little less toxic and harder to absorb threw skin....
Kero and diesel leave alot of oil residues while safety clean dries really well...although I've noticed that it doesn't react well to some of the rubbers Toyota uses such as the rubber bonding in the stock shift stick...it melts the rubber and damn near turns it to a grease.
jdub
Feb 10, 2006
10,730
Valley of the Sun
IJ.;1366160 said:
Whatever you use make sure it doesn't have a low flashpoint as one spark will fuck your whole day (and face, hands and arms)
Yep! Part of the reason I prefer diesel as a solvent.
Kerosene: 100-162 °F
Diesel: 126-204 °F
Either will leave an oily residue as stated earlier...I'll sit the part out in the AZ sun for a couple hours and it's not a problem. ;)
