yeh... anyone know what's wrong? this is the second pump i've put on, and i know for sure that it worked fine before... anyone have any experience w/ this?
89jdm7m said:hm..... it doesn't seem loose, i made sure to get it on w/ the right amount of tension... i'll double check tomorrow tho :-/
Jason T said:Put the correct fluid in it you must run dexron 3 ATF
IIRC it says that right on the resevoir...sleepersupra said:really you don't use just regular p/s fluid????
