The other night a friend and I were out in my 89 turbo, and being the idiot that I am i accidentaly went to full steering lock mid donut. When the smoke cleared there was a rather unpleasant whine from the power steering pump and a noticable vibration (possibley cavitation from excessive heat?). The problem cleared itself up however exept for now there is always a tiny spot of oil under my car when I park it overnight. I have instpected the leak extensivly and have found the steering pump and surrounding components to be damp with some sort of oil. I can not tell if the oil is steering fluid o just oil from an old engine oil leak. Is there a common place for mkIII's to leak steering fluid from? And also what are some suggestions to remedy the probem, perhaps I should just forget it and do the 1JZ swap I have been dreamin up Any help is aprecciated and thanks for your time.
