Hey, My friend is having issues with his power steering. Symptoms are as follows:
1. Reservoir cap is leaking
2. When cap is removed the fluid is super foamy and if you leave the wheel turned completely either way fluid constantly overflows.
3. Very hard to turn the wheel both ways.
I don't see any other leaks other than the cap.
I was told that a bad pump can cause the fluid to bubble up and get foamy that way, does that sound right?
Any help with this is greatly appreciated.
