power stearing leak
lppro
LP Performance & off road
Apr 21, 2007
895
Sugar Hill, Georgia, United States
is this a common problam with older suprs? im trying to figure out whare its commin from and i just wanted to see if there was a hose or fitting that commonley has problams before i start tring to find it..
thanks for the help!
staticpat
Supra Chair!
Birmingham, AL
In my experience the high pressure line develops leaks sometimes. Other times it will just leak out the rack seals.
Replacing the high pressure line is expensive from Toyota, but you can adapt stainless braided line to work.
Pulling the rack and replacing the seals is a tough job. I had luck on one car by just running some ATF Stop Leak through the system and it worked.
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
I have had a leak for a long time but never been able to track it down with everything connected. When I take my turbo off for rebuild and upgrade I'm hoping to have better access to everything so I can track it down.
bryanintexas
aaarrrrrggghhhh!!!!!
Apr 4, 2005
605
spring, texas
Front pump seal is a common leak area. A re-seal p/s pump kit can be ordered from the dealer for around $60. High pressure line is a common one as mentioned. Driftmotion (see vendor section) has a reasonably priced replacement. Whichever it is, make sure you replace the crush washer/gasket on the high pressure line @ the pump.
