power from a N/a feels weird now like it lost some
Toyotaxtreamteam
231
Mass
could be me but i feel like i lost some low end power like once it gets to the 4000 rpm range its fin kicks me into the set and all but off the line feels slugish any toughts, could this be plugs or wouldnt it be the same up in the 4000 feel slugish help please on ideas, could also be i just got use to the car?
does anyones else act like mine tho like once it hits 4000 you get a kick of power
Toyotaxtreamteam
231
Mass
is there a way toi get that power in the lower rpms, feels like a slug before then bam hits u hard great if it was like that ll the time, i do oval racing and that power off the line would set me up nice into turn one.
so nutings wrong with it right just me geting use to the low power on the lower rpms dam? well i guess i can change my plugs and shit , also what rpm should i be idling i am about 750 to 800
DEFIANT 7M
101MM stroke of INSANITY!
Nashville/Miami
I have an idea......try to change the point of activation witha bleed valve of some kind.
Toyotaxtreamteam
231
Mass
yea that system works off vacuum right, so if we were ablt to control it and maybe get it to kick in at 3500 it would help, but i dunno if they made it like that to make it work great at 4000, but if i had that power off the line would be nice, but i am not alone on the power off the line right
moonpie33
61
castroville
I am having this exact problem in my mk2! the 7m its NA feels like a slug till i hit 4000 rpm then bam
is this just me to are is there somthing wrong here?
clinton
AJ'S 88NA
2,419
Florida
clinton
If the ACIS is working right you shouldn't feel any kick.
What's your timing set at?
gaboonviper85
3,236
Northeast Philly
IJ.;245338 said:
That's the ASIC's induction tuning working correctly, maybe it wasn't before?
If I'm not mistaken that infact means it's not working correctly...the activation is supposed to be gradual...the kick in the pants should be felt at 3400 rpm ruffly when the system isn't operating as it should. My car has never had it working so I get the kick also.
If I'm wrong I appolagize Ian but I remember a past thread talking about how the system would react under boost and I believe it was dub'd pointless....
Dunno Goon I wrote that a long time ago and have seen many discussions on it's actual operation but never anything concrete.
90% on NA dyno charts I've seen have had the spike at 4k so maybe they're all broken ;)
Mine wasn't guttless below 4k as some have described but had a noticable kick in the pants at 4200.
gaboonviper85
3,236
Northeast Philly
Yeah true but what makes me wonder is obviously shit don't fix itself and he notices a "kick" now....when the system doesn't work then you will indeed feel a significant powerband effect...he didn't notice this before.
Suppose it's different on everyones car but I'm just regurging info that I've read on the forum...I really have no honest clue...sorry for railroading.
slightly_red_MA70
Holy S*** I own a Racecar
Jan 24, 2009
417
Canada
i can feel mine kick in at 3500RPM when the car is cold but once it warms up i cant feel anything at all just smooth acceleration the whole way
