power, but starter doesnt turn
yoshi7182
brokanic
Dec 12, 2007
7
Hawaii
88 supra n/a swapped w/ a 7m-gte
blew the head gasket, just put everything back together
everything gets power except the starter doesn't turn
doesn't have the sound of when my cps wires were loose
any ideas?
also fuel leaks out the banjo bolts, just bad crush washers?
and i forgot where the ground wires on the intake manifold side go
thx
Kckazdude
1,239
Memphis, TN
Auto or manual transmission?
The crush washers at banjo fittings should never be reused. Replace these before anything else.
The ground wires attach to the intake manifold. Make sure you havent run these to the starter by accident.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
if your starter doesnt work i have one on hand i can send if you pay shipping. just pm me your details and i can get a shipping quote (take the starter to a parts store to test to eliminate that as a reason)
yoshi7182
brokanic
Dec 12, 2007
7
Hawaii
manual trans
i put new crush washers and theyr still leaking
so the brown ground wire and the white ground wire from the wire harness on the intake manifold side attach to the intake manifold?
Kckazdude
1,239
Memphis, TN
yoshi7182;1026694 said:
manual trans
After attaching grounds, if it still doesnt start, check all connections and cltch saftey switch.
Disassemble and clean all surfaces and try again. Should be good if new washers.
Yes. This may also get the starter to working for you also.
yoshi7182
brokanic
Dec 12, 2007
7
Hawaii
dam i figured it out, i forgot to attach the trans ground, it was hidden under some stuff so we couldnt see it
but now we hit another problem, the starter turns, the car starts, then dies out right after
i changed these plugs only 2,000 miles ago, but im try gonna replace them anyway
any other ideas what it might be? igniter? cps?
yoshi7182
brokanic
Dec 12, 2007
7
Hawaii
k, so now i cant get the car to idle
it revs pretty strong, but just wont stay alive
any idea whats wrong?
i think i put the cps back in wrong
or possibly forgot to reconnect a sensor?
Aspec
Supra uber alles
Dec 22, 2005
261
Surprise, AZ
billspreston01;1028760 said:
not everything throws a code
Read the last line in his previous post.
Now, name a sensor that effects idle that when disconnected won't show a code.
With that said, any posted question regarding driveability that makes it past three responses without someone helping the OP with the first step in the diagnostic process is a waste of everyones time and enforces bad habits.
And some people wonder why 50 posts into a thread some dumbass will post "oops, forgot to plug in the AFM"
_
