Power antenna mounting
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
I don't know if I am retarded, blind, or I have lost parts, but for the life of me, I can't figure out how to install the power antenna. Keep in mind that I have had my car apart for over a year, and my rear quarter panels were replaced. Is there some sort of bracket that the antenna attaches to? Surely it cannot just hang from the top nut. Also, if a bracket does exist and you have one, pm me...I need it.
gtsfirefighter
SM Expert on White trash
Sep 26, 2006
2,966
If you're replacing it with an OEM antenna it should be pretty clear. I highly stress "should be". There is a place where the antenna bolts on If it's an aftermarket antenna then you'll have to do some fabricating with a steel strip the should have been provided. Again highly stress "should be".
