Okay, let me explain what has happened. This has occured over a period of about a year of using my dual stage boost controller.
I got my car and shimmed the ct-26's wastegate to 12 lbs. Then I removed the shims and installed the turboxs dual stage MBC. I used to build full low setting boost and click the switch for 15 lbs. I would imagine that it makes the wastegate close again. Now after a few months i have had serious boost creep. It will hit full low boost and without clicking the switch creeps up and up and up then it slams fuel cut.
Is it possible to wear out the wastegate actuator and or wear something out?
