Possible to just replace Antenna and not whole assembly
JDMMA70
2,550
Houston
my antenna on the supra only goes up half way and stops I noticed that the middle section (part that's stuck is bent) so is it possible to just replace the rod and not the entire antenna assembly? I can get a video later showing you what I mean by stuck.
Thanks
~JDMMA70
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
RazoE;1374229 said:
mine's fucked too...
It never went down, and I forgot when I went to the car wash and the fucker bent in half!!
LOL i did that too, well the guys at the carwash did it...
my motor is fine and all took it out and its laying around somewhere its just the shaft that is broken
JDMMA70
2,550
Houston
Just purchased a brand new antenna rod/mast from toyota now does anyone know the steps to replacing this????
zolpix
Supra in the making...
Jul 19, 2008
47
New Zealand
Does your radio still work without it? Mine as it did the same thing and always made a horrible noise, i removed it just to see what reception i would get... lol i get better reception now its gone
ForcedTorque
Join the 92 Owners Group
Jul 11, 2005
6,099
I've done it both ways, and you don't HAVE to disassemble you entire car to do it. It does make it easier to get to it, but it's so much extra work.
I was hoping that the link would show a little something about replacing the mast itself.
JDMMA70
2,550
Houston
ForcedTorque;1376046 said:
I wish someone could verify if our cars were the same as that. Are you going to attenpt to do it that way?
was thinking about it theres another video of someone doing the same procedure on a SC300, but i may just go the safe route and remove the whole thing.
JDMMA70
2,550
Houston
Just replaced it ForcedTorque you were right i didnt have to take out the motor, the nylon cord is just screwed onto the Mast took 20min tops to replace, now it works fine included a little video if anybody might be confused as to how to replace it.
