Possible ground problem? tips/advise?
bombinuass
431
Dahlonega, GA
Ok guys every time i step on my brakes my climate control lights up. just like when you turn the headlights on the display lights come on. but it happens when i hit my brakes also. and also i have a brake light problem too. sometimes both work then sometimes one works and sometimes neither work... any ideas guys? first place to start looking? i dont know if theres a sensor or something that could be bad or if its in the wiring itself.
Steve_N
Louisville KY
Sounds like wiring issue with climate cntrl. Did you add anything such as turbo timer, EBC,Gauges etc? If so check there & definitely check the DS Kick Panel fuse junction box along with under dash wiring. For the Break lights check the bulb holders for loose wires & corrosion on the sockets. Also check tail Light failure box
