possible clutch problem
supramacist
1,501
The Grassy Knole
I just went out to get a bit of gas for my supra. 1st gear 3000rpm's 15 mph. 2nd 3.5 and 4000 rpm's. 3rd gear same thing, 4000 rpm's and it is a struggle to hit 20 mph. The engine is reving just fine. I think my clutch is slipping. Can anyone give me some suggestions as to what the problem might be??? thanks for your time everyone. mike
7M-GTE
ROCK$T@R
Apr 2, 2005
535
KC
it's probably your clutch... if your clutch is fully engaged when your hitting 3.5k rpms and you're only going 20mph... I'd say clutch...
L
lanky189
Guest
you should have smelled it if it was slipping that bad.
first thing to check is your pedal/rod adjustment..
supramacist
1,501
The Grassy Knole
Oh I could smell it. I think sinve I can't get any of my supposed buddies to come over and help. I"m probably going to take it to toyota. I'm pretty sure it's the clutch. thanks guys. And by the way congratulations on beeting anorexia. I called a number of shops and toyota was within 5$ of all of them and can get me in there nore quickley. Thanks guys and any other opinions would be appreciated.
7M-GTE
ROCK$T@R
Apr 2, 2005
535
KC
better make sure toyota will actually do it... the toyota dealership around me won't work on a car that is more than 10yrs old if it hasn't already been worked on at their shop...
Squid699
Manic Mechanic
Chesapeake, VA
absolutely the first thing you should check. when i put in my turbo engine my clutch was slipping that bad, just because my pedal needed to be adjusted. check that out first.
supramacist
1,501
The Grassy Knole
Squid699....,I'm running a 7mge.., and I'm finding out that even though they are the same breed of car.., They are defiitley not the same in everyway. GrimJack..., I'm definitley going to be changing the rear main seal.
supramacist
1,501
The Grassy Knole
more coming, hang on
supramacist
1,501
The Grassy Knole
sit tight, i have more coming
supramacist
1,501
The Grassy Knole
stillllllllllllllll to come
supramacist
1,501
The Grassy Knole
same bat time
same bat channel./
supramacist
1,501
The Grassy Knole
THis hole is where the air intake leads to. I removed the piece that goes from the end of the tube obviously. I may go and get a dremel and really open that up and let it be at that. Take the circular end cap off of the entire thing and get rid of that fat ass'd canister in the middle of it. I'm thinking about some 3 inch type of radiator hosing clamped from one end to the other?????? Just thought I would run it up the old flag pole and see if I could gtes a lil golden shower. Frank Zappa..............., I liked it.
supramacist
1,501
The Grassy Knole
I didn't notice the oil leaking thanks Jonathan. Part of the problem...., Part of the sulution, or landscape. You guys decide. Some of these parts under my engine have a rustproof coating that should last the life of the car. Yes.., and Thank you
L
lanky189
Guest
kinda preaching to the choir there supre. squid did a complete na - turbo swap...he knows more about the 7mge than most turbo drivers do...
again i urge you to check your adjustment...its very possible its just out of whack..
also its free..
Squid699
Manic Mechanic
Chesapeake, VA
thanks lank - saved me some time. and it should be the first thing you check, regardless of what clutch configuration you have. start with the simple stuff and work your way up
