Summary: Short drive to work the other day and every time I touch the brakes my cd player and A/F gauge restarts. That night I go to leave and nothing works. No power locks, lights, ignition, etc. Check the battery and the neg connector is completely loose. I tighten everything and try to jump the car, but still nothing, not even dome lights. Took the battery to advance it tested good and to recharge. After the recharge it tested bad. Purchased a new battery happy that it was the problem, but still no power. All the fuses checked out, and all of the connections are tight. From my searching it appears the wire from the positive side to the fuse box controls all power. Even though it is tight, it does look brittle.
Question: The wire goes from one thicker wire to two smaller white wires. The thicker wire needs to be cut off, but then the wires will be too short. What is the best way to extend these wires? Can I split the two white wires and extend separately to the positive terminal? Solder, butt connectors, or what?
It's tax season, the supra is stuck at work and I am limited on time. I apologize for starting a new thread as I did find several with this issue, but they typically wandered into other discussions. Thanks for any help.
John
John
