posible HEAD truma
supraman508
496
maryland
I instaled a new head gasket,timing belt,plugs and 20W-50 mobil oil do to my rings are bad.But i'm gona display a pic of my valve cams, the shafts under my valve covers.Let me know if my Titlement is false.IT'S SAINT PADDY"S DAy:drink1::: alky ::do they look timed right
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
you need to show us the sprockets... not the cams. and you need to make sure the cam dowel pin was put in the center hole in the cam or they will get messed up too.
supraman508
496
maryland
:cry:
who da what in the sprocket dowel pins where who::dunce::saints paddy's day brother.l.m.m.a.o
92nsx
2,957
Clearwater, MN
supraman508;1274338 said:
:cry:who da what in the sprocket dowel pins where who::dunce::saints paddy's day brother.l.m.m.a.o
What did you just say??? Showing us the pic you posted dose nothing for us to help you.
supraman508
496
maryland
CyFi6;1275133 said:
I think you have some major head trauma
now that i'm sobber:cry:for now,on the right side of the block near the back on passanger side their is wet traces of like oil or coolant.on my exahaust header near the egr cooler something is leaking,and i know it's involved in my hesitation of pick up speed.last year i put a new gasket under the e.g.r cover that came with the gasket set.something is leaking and i replaced the rubber coolant hose that is right ontop of the e.g.r cooler.i'm trying to explain as best as possible.she idle's fine and starts right up as well,just have that sound and lack of proformance.
dumbo
1,911
Albera, Too Far North
Hmmm, I have understood your posts, but your not really explaining your problem very well. Start there.
And the TSRM explains valve timing the best.
Why was your engine apart there, and is you car running nowÉÉ
Dont you love St. Paddies:icon_bigg
supraman508
496
maryland
T.S.R.M...who would of thought,thanks pal:biglaugh:
supraman508
496
maryland
dumbo;1275273 said:
Are you being sarcastic....Whats your problemÉÉÉÉ
É=Question mark..not my computer:nono:
na man i'm not being sarcastic brother,but if i'm seeing leakage at the back of the head i'm thinking that i might of messed up a valve or cracked the head.I just had my valves replaced a year ago.i'll try to get a pic up tonight.
