port matching intake manifold
mk3ukr
292
Odessa, Ukraine
mk3ukr-supra.net
Tomorrow I will be fitting my new intake manifold with 4 mm phenolic gasket. I want to fabricate locating pins to prevent any movement of manifold flange relative to head ports.
My question is: Is it OK to enlarge slightly head port entry to create reversion dam or it works only for exhaust side?
To port match intake with engine in car is big PITA
Thanks
Vladimir, 89T
rakkasan
Currahee!!
Fort Campbell, KY
figgie said:
well IF you do decide to port match. Do not do like in the exhaust and smooth it out. The finish has to be somewhat rough.
If you have a carb'd car, that is true as you need the turbulance to keep the air/fuel mixed. With a fuel injected car you don't need the turbulance so smooth porting is desired.
figgie
Twin Cities, Minnesot-ah
wrong answer. You do need the turbulance to help keep the fuel atomized otherwise you start wetting the walls and that is never good ;)
lzalusky
19
Sacramento CA
There should not be any fuel in the intake system as the fuel injectors are in the head a couple inches away from the intake valves. Fuel atomization is not the issue with a smooth finish on the intake manifold. I have read that a rough finish on the inside of a pipe will create a turbulent boundary layer between the air and pipe wall, actually allowing better velocity and flow than a smooth surface. I would probably just polish the inside of the intake manifold though.
mk3ukr
292
Odessa, Ukraine
mk3ukr-supra.net
I remember reading somewhere intake ports are made rough to create turbulance near the port walls. At low load/rpm it has effect of smaller runners and improve low rpm torque. At high load/air velocity this effect cancelled and you have bigger runners for good high end HP. This explanation makes sense to me. But AFAIK all tuners agree that intake ports have to be roughened up.
Guys, my main question was is it OK to make head ports entries slightly larger then manifold ports. Like reversion dam on exhaust side. To port match manifold + head + 4mm gasket is major PITA when engine in the car
Thanks
Vladimir, 89T
89mkthree
supies ignore irish luck!
Apr 12, 2005
138
near chi town
ok stupid question. what is this "reversion dam" thing? ive been planning to port my head and manifolds for a whilea and ive never heard of this.
figgie
in it most simple explanation
the hole the air is going to is bigger than the one it came out off. :)
hotsup
25
Melbourne, Australia
Over many years of seeing port matched & polished manifolds (intake & exhaust) & cyl. heads the surfaces have always been polished to "as smooth as glass" finish. So i don't know why it should, all of a sudden, change from that. :dunno:
figgie
you are highly mistaken
even the v8 guys know never to polish the intakes. 80 grit is the highest grit recommened on the intake side,
http://www.sa-motorsports.com/diyport.shtm
Step 2.
This is the guide I use, please notice the v8 they are working on ;)
tkvtec
12
CT
That's a nice guide. Thanks for posting that. I just wish I knew of that when I had my intake manifold off.
