i have a popping sound while i'm turning at slow or fast speeds. Tried searching but couldn't find much. I was thinking lower ball joints but maybe tie rod ends, what are some checks i can do to find out for sure what it is?
TurboSupra7 said:i have a popping sound while i'm turning at slow or fast speeds. Tried searching but couldn't find much. I was thinking lower ball joints but maybe tie rod ends, what are some checks i can do to find out for sure what it is?
yup,is coming from back there? if it is,one of your cv joints on the axle shaft is failing. when you get time juck up the rear end off the grond and manhandle the wheel and rock it back and forth to see if there is ant clattering or movement.cjsupra90 said:first off, is it comming from the front or rear?
xarewhyayen said:to check ball joints, jack up the car so the side in question is in the air(lower ball joint unloaded), then grab the tire at 3 and 9 and shake it back and forth, if it has looseness to it, replace ball joints. Also check to make sure all nuts and bolts under there are tight... like the control arm and such
