I was wondering if anyone make polyurethane motor mounts for the supra if any one knows let me know.
i dont have mounts they broke when my motor blew up. so im looking for upgrades.Evilempire1.3JZ-GTE said:lol you have an 88 you dont need them at all!!!
the square motor mounts are bad ass the rubber on them is thin and haves verry little play.
Also the square motor mounts hande a lot of HP more then the liquid or even the trd round ones you see on the 89+ supras.
Seriously you dont need it unless your building your car for show to show off so bright red rubber.
CryoSlash said:speaking of motor mounts, what would be the best way to make these solid?
:icon_surp :icon_surpbecauseican said:I am working on solid 87-88 square motor mounts right now.......:evil2:
care to explain where? im sorry but if i had my car here i would be able to figure it out myselfdrjonez said:not difficult- weld on 2 plates.
supra90turbo said:Well, they're square.
Rubber in the middle, steel on the ends.
Weld strips of steel between the steel ends.
Voila. Solid motor mounts.
88supraFAST1 said:im looking for more then some homemade back yard garage stuff im looking for something that has some track time knowing that it will work and track proven.
Awesome! What we need in conjunction with that is a solid trans mount.becauseican said:I am working on solid 87-88 square motor mounts right now.......:evil2:
Enraged said:a block of aluminum will last, and if you clean it up, it will look professional. if you want to pay $100 to get the same performance as a $20 item will get you, thats your choice.
