Wiring specifically for the pump and spark? You need the EWD. The only thing I can think of is a wire is grounded and blowing an EFI fuse. More like an EFI relay not working.
Your CPS can ohm correctly and still be bad. I havent seen too many faulty CPS's, mostly faults in the wiring.
i had one where the pickup coil (green wire) was dead. was missing but still ran (bless its little heart) till i cut it up and soldered a new pickup in.
