Ok
So I have a new FFIM and extended the harness to the TPS about 1 foot. I taped it all up really well, and soldered the connections. I did use bigger wire, I think it was like 14 guage? Anyways, when the TPS isn't plugged in the car revs fine; holds idle fine (about 900) and is very driveable like this. However, when I plug in the harness to the TPS; if I rev anything over 1500 and try to hold the RPM's there, it revs and drops, revs and drops on it's own...
At any RPM higher than 1500 this happens when the TPS is plugged in. When the harness isn't plugged in like I said the car runs beautifully; except for the massive fuel dumpage =x
Someone suggested a new TPS; but this one is only about 1 year old... I don't have the time to swap out to different TPS's since I don't have any to swap out too..
Anyone know what could be causing this? Maybe my solders sucked dick(i thought they were pretty damn good) or I didn't tape the wires up enough and the sound is interfering with the signal?
Any suggestions from someone who had the same or similar problems and has fixed it now?
Thanks,
Kyle Ackerman
Thanks,
Kyle Ackerman
