Hey, I'm really sorry for posting a thread on something I'm sure has been covered a million times, but the search doesn't work and I just spent over half an hour manually going through threads page by page. Anyway, so here’s my problem. I’m just trying to finish up a BHG fix and rebuild on my 1987 turbo/targa/5spd and I have run into a few issues.
One (and this is the biggest problem)- I have fuel, I have spark, and I still have no running motor. Is my timing off? And if so, does the damper pulley have to be removed to reset timing? And if it does, does the radiator have to be removed to remove the pulley? Does anyone have a link to a how-to for setting timing?
Two- if it is not the timing, what else could it could be? I have a new (well used but in good condition) CPS and followed the TSRM directions exactly to install it, lining up the dot with the line on the gear, but when I push it in with engine at TDC it moves a little so the pickup on the cps doesn’t line up perfectly (possibly because of my timing being off?)
Three- I’ve removed the power steering idle up VSV, my power steering doesn’t work anyway, so don’t need that one, would this effect the car starting?
Four- For the life of me I can’t figure out where the oil pressure sending unit connector plugs in at. Shaef described exactly where it goes but I still couldn’t find it with everything in the way. Does anyone have a pic?
Five- If there’s any other reason why my car won’t start that I haven’t mentioned, what is it and how do I fix it?
Any and all help will be greatly appreciated, as I really need this car running, it’s my only transportation, and I’m soon having a kid, so I’ll need a way top get my fiancé to the hospital, and I can’t afford to have Doc Jonez come over and fix it for me.
