ok this is the situation. i have two motors lets call them a and b a=good b =bad
i was doing a motor swap and i was taking motor b out of the car so that i would be able to drop motor a into my car both na 7mges. so here the problem i was trying to pull it out and i noticed the fuel line that is connected to the block was still attached, but i need that line becaseu it connects from the fluel tankn to the motor. so since i did not have use for motor b i cut it on the upper part of the line after the little bolt thing that is connected to the block.(because i could not remove the bolt the held it to the line) now on motor A, it has that little metal thing that leads fuel into the motor already, so i need help trying to take the bolt off of the line from the body of the car, so that i can simply bolt the fuel line in and get set. please help because i cant do it on my own and i need advice on how to take it off.
i hope its not too confusing.
