please help w/ install
mtoxracerfss
Boost Addict
Oct 8, 2005
177
Toledo
I have had an aftermarket FPR for 2 weeks and i havent installed it yet. I was wondering what the process was for installing it? Does it bolt on? What do i need? Any help is GREATLY appreciated.
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
It simply replaces the stock one on the front of your fuel rail. Take old one off, put new fitting for fpr line on it, attach to fpr, then run the other line to return and set pressure with vacuum disconnected apparently, to get the pressure correct. That's what I hear anyway.
eric
Stretch
Toronto, Ontario
Basically, and also you won't be needing the stock j-tube, so you can block that off and bypass it by running the line right from the fpr to the return. The bracket lets you mount it to the shock tower if i am not mistaken.
eric
