I have recently sourced the proper wiring harness for my 1992 turbo, and replaced the repinned 1989 harness that I was using. With the 89 harness, I was able to use the older O2 sensor, and it is the only one I have at this point. My plan is to remove the connector from the 89 harness and add it to the 1992 harness, so I don't need to source another sensor. Both harnesses use a 3 wire sensor, but they have different connectors. I just need a little guidance as to where each wire should go to make this work.
From my searching, I believe the 2 black wires are heater wires. Does it matter which one is which. I would assume that they go to the two lower pins that are together. Am I right? And that would leave the blue wire to go to the pin where the white wire was on the other, at the solo pin?
Here are pictures of both connectors and the wiring for each:
The connector from the sensor on the earlier 86-90 sensor and it's wiring
The round connector from that same 89 sensor
The square 92 connector
And the 92's wiring
And the 92's wiring
