Please help me identify these parts removed from the intake manifold...
Neilpryde
Edmonton AB
Hello, i have a 1992 Supra 5 speed with 7MGTE that i purchased six months ago. The starter has failed, so i have undertaken the task of replacing. I removed the intake manifold and corresponding hoses, bolts, wires and i took videos to make sure i knew how everything went back together...except i made a mistake, and there were two pieces lying on the floor and i can't figure out where they go...i have the new starter installed, but i don't want to proceed until if figure out where they two pieces go.
someone hopefully can help me out. If more photos are required please advise.
thank you.
spooln30
milwaukee,WI
Those are for the IAC. Otherwise know as the idle air control valve. The metal one way valve first, the way its sitting on the table the bowl looking part of it goes into the mani, then the rubber ring.
