I have been having trouble controlling boost from the beginning, but after getting a quality boost controller and trying everything I still cant get rid of my boost spike. my mods are as follows:
57 trim CT26
2.5" intercooler/piping
full 3" exhaust
Apexi intake
Supporting fuel mods
Wastegate shimmed with 2 washers- Base boost of about 8PSI
Turbosmart Eboost Street electronic boost controller
I am aiming for a solid 16 PSI but cannot run 16 psi because spiking to 18 psi is putting me into a danger zone. If i MUST, I could probably adjust my tune to allow me to spike and not hurt anything, but I would rather have solid boost control.
As it sits now, boost will spike 1-2 psi and quickly come back down to a steady PSI. I have altered with the settings in the EBC as much as possible to where i should have no spike, but i still have a spike. I tried my Hallman pro manual boost controller and experience a spike as well as drop off with this setup.
My boost only line comes from the compressor housing, and the actuator line goes directly to the actuator. Hoses are tight and neither is over 12 inches, no leaks.
Running on base boost there are no spikes, but as I start raising my PSI the spike becomes more apparent. Here is a graph of base boost. X is sample # and Y is KPA absolute.
Here is a video of my boost gauge in 2nd gear where you can clearly see the spike. This is with the electronic boost controller. With the manual, the spike is still there but doesn't seem to drop quite as fast, but more of a gradual drop off.
http://smg.photobucket.com/albums/v313/cyfi/?action=view¤t=MVI_2134.mp4
Here are some graphs of the spike while running the EBC (multiple boost settings)
Here are some spikes when using the Hallman pro manual boost controller (set around 15 psi)
Things I have checked:
Wastegate actuator moves smoothly
No leaks in WG diaphragm
1 or 2 small cracks around wastegate flapper opening
Vacuum lines tight and sealed 100%
No apparent boost leaks (have not done a boost leak test though)
I cant really think of anything else to check, please help me if I am missing something obvious. Any help is appreciated.
57 trim CT26
full 3" exhaust
Apexi intake
