As some of you know, I just put a motor in my 87T to replace my crashed 90. Motor is in, and as far as I know, everything is hooked up correctly. I am not getting anything out of the key except a click out of the starter relay. I have run a wire to be sure the starter is good, and it is. From there, I tried to get the car started, with no luck. I had Jim (N2FISHN69) over today helping. We found that it is not getting fire, or fuel. We jumped the clutch safety switch, and still nothing out of the key. We also checked the 6 wire plug at the igniter, and got nothing with the key engaged as starting. I do have all power inside the vehicle (dash lights, locks, power windows). We have checked all fuses under the hood, and the lower (engine)level in the kick panel. I am assuming there is something that powers both the ignition and the fuel pump. Please point me in the right direction.
