please explain
supramacist
1,501
The Grassy Knole
Some one please explain..., what exactlly is an na/t. Obviously it's a 7mge converted to a turbo wich is cool, but I Know nothing about it and would like to know lots if any one could see their way to telling me what's up. I wouls appreciate it greatly. Thanks for your times everyone.:icon_evil
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
Do a search for NA-t You'll get thousands of hits...
In a nutshell... NA-T is get all the turbo stuff off the turbo supra, put it on the NA and it becomes NA-T.
supramacist
1,501
The Grassy Knole
I figured that but how does it go on???/ And why not jus swap to a 7mgte???
I like the idea it's just......., I womder about it or I am leary about it. teach me more please. It looks like a piece that you bolt on top somehow and run the hoses. I doesn't look like a real turbo.
SupraDerk
The Backseat Flyer
Sep 17, 2005
546
Tallahassee
Due to the higher compression you run more mid range power than a gte though, and if you don't want high compression you can always get low compression pistons.
supramacist
1,501
The Grassy Knole
I get what your saying. You are going na/t because you don't want to do the engine swap and you'll feel better about pissing the money away instead of swapping for more horsepower. It seems to me like a big way to cut corners. But it definitley seems easy enough and if you don't want to swap......., this may be the way to go. I think I should do some research.
bluemax
The Family Man
Orange County, CA
The full NA>T is not just an engine swap. Just about everything is different in a GTE. The ignition is different, the ECU is different, the injectors are bigger........
The NA>1/2T is OK for low boost. Some guys may not want a turbo monster and do a complete under hood swap out, just a little more power to play with.
It kinda depends on what you want. The NA>1/2T is what someone would do on a NA car that doesn't have a turbo option from the factory.
supramacist
1,501
The Grassy Knole
I don't want to seem rude bluemax. But for 10 psi max when you know you can push 16 if you take care to do it properly. I'm not trying to dis anyone.
Now for the real question......., the fan shraoud. Do I need this? can I take it out? or is it a must in the permanent department????? do I lose or gain from removing this piece??? Any comments would be extremely welcome.
I'm tired of being my supras bitch. I bought it to work for me. ha ha ha ha ha
SupraDerk
The Backseat Flyer
Sep 17, 2005
546
Tallahassee
There is a such thing as having too much power for what you're trying to accomplish. If you want to use the MKIII for drifting, you only need between 250-300hp, so why build up an engine that puts out 1000hp? That's overkill. If you're using the MKIII for autox, the fastest you'll probably get up to is like 55mph so again, why have an engine that puts out 1000hp when you only need about 250-300? Comparing an NA-T engine to the stock GTE you get more power out of the NA-T in the low and mid range due to the high compression, ideal for drifting and autox. So like bluemax said, it all depends on what the driver wants and is trying to do.
89Joe
POTATOES!!!!!!!!!!!!!!!!!
Jul 22, 2005
300
Missouri
Well, the fan shroud helps focus the air towards the engine. I guess it really dosnt matter, but I think it actually might increase the amount of noise from the fan if you take it off. This is just a speculation but I guess it wouldnt matter to much if you did.
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
Fan shroud is designed to pull more air through the radiator and not really to focus air at the motor.. :)
Plus, They save fingers..
supramacist
1,501
The Grassy Knole
ok....., this is good. I know the shroud saves fingers. but the last owner broke it . It's rigged with wire to stay. I need a more in depth description of what to expect if I remove his thing......, it's hanging on by one bolt and some wire. Do I lose hp if I remove it? Or would I be better off tho remove it and fix it and put it back on??? I personally like it off. I wonder if it doesn't restrict air flow instead of letting shit breath.?????? I'll check back later. I have to go out to dinner with my significant other. Please help me make up my mind on what to do with this so I can get started tomorrow. I also need to know what else I can remove to make more room in the engine bay to work. I appreciate allof the time you guys tske to answer my questions. Thank You very much.
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
I would take it off before it falls off and breaks something else. Then watch your gauges until you find another shroud or you could replace it and the fan clutch with an electric fan/shroud combo. :dunno:
s383mmber1
3,614
Somers New York
Theres an edit button to go back and edit your posts so you dont have like 5 million. And could you please clarify who exactly your talking to.
Liek when you said that last comment about turbo, who exactly were you talkign to?
