Piston decisions for a 7mgte
Mk3Dreamer
4
New York
Building up a 7mgte from the ground up. I'm just stuck on what pistons to use. I've heard good and bad things from CP and JE pistons. So im just looking for more info on these two company's or if anyone as had really good feed back... Thanks
toyotanos
What will we break today?
2,841
Coon Rapids, MN
I have good feedback for my JE pistons. They have held up well to all my use and abuse, mildly questionable tuning, and racing. Had then coated last rebuild and made a bunch of power on 'em without an issue.
I have a bud local to me who melted Probe pistons where the valve reliefs were- seemed like it got a little too narrow on the crown (or his tune/lack thereof)
No experience with CP.
Another local guy had Ross pistons which clattered a bunch, but held all of his power (never dyno'd before he threw a core plug)
AbsoluteSpeed
735
Edmonton AB
What are your power goals for this motor? And how are you going to use it?
JE pistons run a higher compression ratio at 8.9:1 vs the CP's 8.4:1. So the JE pistons will create more low end power but you are at a higher risk of detonation (with good tune it wouldn't really be a problem). The CP pistons are about 5 grams heavier then the JE pistons, this will also affect the responsiveness of the engine (I don't really know how big a difference it will make though).
http://www.briancrower.com/makes/toyota/7mgte_pistons.shtml
Now I used the JE pistons on my first engine build and can't say I would do it again. It was mostly the fault of the engine builder but the motor was built on the loose side of the tolerances, this caused the pistons to rattle until it was at full operating temp.
Next time I'll go with a piston with a longer skirt, make sure it is built a bit tighter and possibly get the pistons coated.
Mk3Dreamer
4
New York
I'm trying to make as much power as i can while being safe. I'll be driving the shit out of the car ha...
JDMMA70
2,550
Houston
I have probes, had the machine shop smooth the sharp edges, but if I had to do it again I would buy CP's
supraguy@aol
Well-Known Member
Dec 30, 2005
4,238
Atlanta
I bought Wiseco's, but I really can't say if they're good or bad, as I've never started the engine.
I CAN say that they haven't rattled ONE BIT so far... lol.
Mk3Dreamer
4
New York
Ha.. i've heard bad things from Wiseco. Like the rattling and braking rings do to it.
JDMMA70
2,550
Houston
Piston to Cylinder Wall Clearance, and Ring Gap is important, to much clearance and any piston will slap.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,238
Atlanta
I dunno, never heard that. plus the skirts are coated, and it has offset pinbores to reduce slap found in other brands, so...
Mk3Dreamer
4
New York
Now I've never heard of coating pistons. Can someone explain the hole idea behind it and the reason for doing so...
Is there like different coatings you can do for what your looking for?
AbsoluteSpeed
735
Edmonton AB
Basically there are three different coatings.
Coating the top of the piston with a thermal barrier reduces heat transfer and prevents hot spots causing detonation.
Coating the side of the piston with a dry film lube reduces friction. Less friction= More power.
Lastly, coating coating the bottom of the pistons will help shed oil. This keeps the weight down and is supposed to keep the piston cooler.
http://www.techlinecoatings.com/articles/Coating_Pistons_Article.htm
If I had to rate each piston.
Probe= Cheapest
Wiseco= Most street friendly
JE= Full race piston
CP= Happy medium between JE and Wiseco
