In the process of repairing a hybrid 1992 2jzge/pre89 body harness and some information escapes me.
pin numbers known on C1 but their terminations are important to me.
1. White ---------------------- goes to something related to hazard,horns,turnsignals ?
2. Black and yellow --------- memory for ECU from 15amp EFI fuse?
3. Black and Orange--------- ecu relay signal to the EFI relay coil
4. Black and Red ------------Power from EFI relay to ECU
5. color?-----------------------airflow meter ground for 7mge?
6. Blue and White------------ A/c water temp switch signal to ???
B1
there are 2 10 guage wires, 1 of which ties to injectors and the other goes to the starter directly?
M1
purple or violet wire goes to defrost relay?
Thank you
B1
M1
Thank you
