I'm having a bit of trouble here guys. My torque converter got here from Yellow13 today (thanks bill ) and upon inspection, I've realized...I'm fucked (or at least ATM).
(picture below)This pilot bearing was meant for a car with a manual transmission, whereas I have an automatic tranny. The reason the bearing/bushing is there is because the motor came from a manual tranny. Anyways, am I supposed to find a bearing/bushing that WILL fit the torque converter, or does the torque converter just sit in the block without a bearing/bushing at all? Any help is appreciated, thanks guys
~BrandoN~
Edit--Little more info: OD of the torque converter stud is 42.6mm, ID of that bearing is 27mm
~BrandoN~
