Pic request: 7MGTE Damper Pulley (Correct)
nsngarage
210
Pittsburgh, PA
I need to see where the keyway and the timing marks are SUPPOSED to be on a 7mgte damper.. I'm thinking my whole problem is the damper spun a little and isn't lined up anymore and it's throwing off my timing.
Not sure if the 7MGTE and 7MGE are supposed to be the same, but one of my NA ones isn't even close to being the same to one of my GTE ones..
THANKS!
Same dampner. Best way is to pull the no1 spark plug and stick a chop stick or something similar in the hole and watch it as you turn the crank to find tdc. Then your not guessing. Also doesnt take that long to pull that one plug.
